  • Everything You Wanted to Know About HDMI Cables. Ep. 7 of the AVSForum Podcast is now live. Click here for details.
NVIDIA Shield Pro + Kodi and audio passthrough
1 reading
10K views 21 replies 11 participants last post by  darien87
#1 ·
I have a NVIDIA Shield Pro plugged directly into a HDMI port on my OLED so that it will play HDR and Dolby Vision files (which works)--this does not work if I plug it into my receiver (Denon AVR-S900W ) because it is not HDR-compatible. I have a HDMI ARC cable from the TV to the receiver. Everything works fine but I get no audio whatsoever from movies with DTS-HD audio or any of my multichannel audio files. Is there any way to get HDR and these files to work without shelling out a lot of money on a new receiver?
#6 ·
You can buy an HDMI splitter that will enable lossless to a legacy AVR. Can't recommend one as it can't be any old one as it must be able to down convert to HDMI 1.4 along with dealing with the EDID. HDfury devices are almost certain to work but are expensive. Personal opinion better money spent in upgrading AVR then band aid solutions for an old AVR. Money tight, search the used market for an HDMI 2.0 AVR as long as no need for 2.1.
  • Like
Reactions: elmoe
#8 ·
I have that problem with my DVD player / TV / Sound bar connections. I have a Shield pro, but the HDR sources for streaming are DD+(Atmos) that will go over ARC. The DVD player has separate HDMI outputs for video and sound, so I can send the sound directly to the sound bar, and the HDR video to the TV directly at the same time.
#9 ·
So I guess I am relegated to either a) the Shield rendering Dolby Vision and HDR if plugged into the TV and missing out on any DTS-HD content or most of my multichannel audio files or b) plugging in the Shield directly into my receiver, getting all of the aforementioned audio but losing HDR and Dolby Vision capability. Unless I want to shell out more money for a new receiver with eARC capability/HDR and Dolby Vision capability. THAT'S not frustrating. I'd be more apt to spring for the receiver if I didn't just spend so much on wiring the room, mounting surround speakers, the tv, etc.
#11 ·
Yes, you can purchase a AVR Key by HD fury. Should be about $150 USD. It will have one input and 2 output. 1 hdmi output to tv and 1 to receiver. Basically it sends full video signal to tv and a 1080p or 720p black screen with full HD audio to receiver. You will lose the receiver's OSD. If you do not care about audio quality, pick up a cheap 5.1 HDMI audio extractor from Amazon. If you do care about HD Audio, get the AVR key. Link: AVR Key 18Gbps | HDFury.com | Connect and Fix everything in HDMI
#15 ·
I know that's the simplest solution (a new receiver). But I have an OLED that can handle Dolby Vision and HDR and the receiver can handle DTS-HD, etc. The receiver also has Zone 2 capability which I use for my whole home audio setup. And it's 90W per channel for this big room. Any newer HDR/Dolby Vision compatible receiver with that much power is going to cost A LOT. If there is a more cost-effective solution I would prefer that since this isn't my main home theater room.
#21 ·
