I have 3x Goldenear Invisa SPS speakers for my front LCR. There's a high-pitched vibrating noise coming from the top-most driver on the left speaker. I observe it audibly between 60-110hz. I have my sub crossover set to 120hz on my Marantz AVR.
When I lightly press my finger along the top part of that rubber part along the edge of the driver, it silences the vibrating noise. I feel like this is a physical issue with the speaker rather than an audio distortion or interference problem. Especially since similar drivers on other speakers and even the same one do not have this noise.
In the attached picture below:
Is this an RMA situation or is there a simple fix I can do myself?
- Red circle identifies the driver with the vibrating noise
- Green dot shows where I can lightly press my finger on the rubbery part to make the vibration sound completely go away.
