  • Manufacturing, Myths, and Misfires with HDMI Cables. Episode 9 of the AVSForum Podcast is now live! Click here for details.
Stacked or side by side subs.
2.7K views 11 replies 7 participants last post by  A9X-308
#1 ·
Now that it is starting to get warmer I can think about finishing my dual SI HT18 sub boxes, That is two 9cuft (internal) boxes with 2 drivers each, I had planned to stack them on their side hook them up together for a 4 ohm load and have 4Kw available to power them. That would give me the added benefits in output of co-location. However, I'm thinking of getting a new screen and it would be acoustically transparent meaning that I could put the subs behind the screen. Now if I leave the subs stacked nothing changes. But what if I put them end to end in an 8' column on the floor? Do you still get the benefits of co-location? Should they still be fed the same signal or each adjusted separetly with individual signals?
I'm thinking it shouldn't make a difference since all 4 drivers would be acting the same from the same location albeit shorter and wider than being stacked. I've been know to be wrong though so I'm turning to the hive of knowledge for a little help. Your thoughts and opinions?
#2 ·
Stacked or side-by-side they are not in the same location.
The output has now moved either vertically or horizontally. I would measure the difference and select the one that gives the best bass response. Vertical works well as long as they are not allowed to move, subs falling off of each other really puts the beat down on corners. This is commonly called "re-entry marks" so pay particular attention to that.
So let the measurements be your guide, congrats on more subs! If you are not sure, just build even more subs and make a quad group--you know you want to! ;)
#6 ·
While more subs is not feasible at the moment I can't say it is a bad idea. However, I believe the for subs lf they are within a quarter wavelength they can be considered co-located. At 80hz that is about a 14' total wavelength so a quarter of that is 42" Now I can't say why I believe that or even if it is true and I can't find any confirmation of it either. I have seen others say the same thing though. Now remember that this is for maximum coupling of the drivers not necessarily the best response.
#3 ·
#4 ·
I can't answer your question about co-locating subs, but I have a question about this statement. How could you wire 2 dual 2ohm speakers together to get 4ohms?
I thought you could only wire them like this: Subwoofer Wiring Diagrams for Two 2 Ohm Dual Voice Coil Speakers (i.e. .5ohm, 2ohm, or 8ohm).
Each box has 2 subs with dual 2 ohm voice coils. Hooking those in series gives you an 8 ohm load per box. Hooking the 2 boxes up on parallel will then give you a 4 ohm total load. Basic series-parallel circuit just spread out.
#8 ·
Hi,
The closer the subs are to the dimensions of the room, the more similar their response will be and so you end up with something more similar to the idea of co-location. The more variable distance the subs are from the boundaries of the room, the more differences you will see in their response and you may need more time management (delay) to get a summation from them as a group unit.
Which is better will be based on your room's dimensions, your listening position(s) and the relationship of your subs as a unit assuming you achieve summation with them from time management. You will mainly see the differences and what's best for you via measurements. I would say try both arrangements and see what your measurements tell you for your room. One setup may have more SPL in a particular range. And one setup may just have a flatter even response across more seats.
Very best,
#10 ·
I'm going to be close to 1/2 placement on 3 sides. Side 4 is full of other stuff so no sub going there which mean one of the other 3 will have 2 or possibly 3 subs. Right now the back wall has a Devastator, the front has a McCauley 18 and the right side a dual 15/12. If I don't get a new screen the new boxes pretty much have to go on the back wall with the Devastator.
#12 ·
If they are less than 1/4 wl apart at the upper xover point they are effectively co-located.
Driver location, laterally or vertically may have some effect on amelioration of some room modes depending upon their position.
