  • Everything You Wanted to Know About HDMI Cables. Ep. 7 of the AVSForum Podcast is now live. Click here for details.
Subwoofer not working with Y adapter
6.7K views 11 replies 10 participants last post by  mdprince
#1 ·
I have plugged in a RCA audio interconnect cable with a Y adapter from my SVS 1000 to the sub pre out on my Denon AVR1910, however no sound is coming out from the sub. The other speakers work fine.
Do I need to try an RCA without the Y adapter or is this likely a problem with the output from the reciever? The sub is new, turns on and makes noise when you tap the cables so I don’t think there’s anything wrong with the sub itself.
#2 ·
If the sub isn't working with music or movies...
1)check the speaker setup menu in the receiver. set all speakers to 80hz(you can tune later) and sub to on/yes
2)be sure you are not using a listening mode on the receiver which disables the sub
3)check the speaker level settings in the receiver, set the bass(usually ranges from -12 to +12) to +6 for now.
Tom V.
Team Power.
#3 ·
Do I need to try an RCA without the Y adapter or is this likely a problem with the output from the reciever? The sub is new, turns on and makes noise when you tap the cables so I don’t think there’s anything wrong with the sub itself. View attachment 3398620
Go into the Main Menu, select Speakers/Manual Setup/Speaker Config., and then set the Subwoofer option to "1spkr".
Once you've activated the sub channel you'll need to do a proper calibration, so use the resources here to your advantage to help you achieve the most optimal results.
Good luck, and welcome to the forums!
TF
  • Like
Reactions: darthray
#6 ·
Use a single RCA out of the AVR and connect to the LFE input on your sub. You don't need a y-connector. Also check the settings on your AVR to ensure you are correctly setting your sub out.
#8 ·
I’ve tried less expensive Sub splitters, and they didn’t work. Audioquest Sub splitter connected to the LFEs worked well for my Marantz AVR system. Hope this helps.
Peace and blessings,
Azeke
