I hear ya'. Storage is not that cheap. Lot's of storage still costs a pretty penny. I've been doing this a while so I've accumulated over the years. Presently I have (10) 8TB HDD's and an SSD housed locally inside my HTPC. I usually purchase new old stock because gig for gig, smaller than state-of-the-art is much less expensive and I look for the deals. As my storage demands grow larger, I retire the older smaller HDD's to backup storage in 8-bay enclosures. That consists of 1TB drives through 5TB drives - 40 of them equaling the local 80TB's . I don't care for RAID, NAS, or any other unnecessary baloney. Sacrificing a couple of the largest drives for these things to run is not in my best interest. JBOD is fine. However, I do use Windows Storage Spaces for pools of the smallest drives simply to save drive letters. Should a drive ever fail while in use, (and in 25yrs or so hasn't) I can simply replace the drive and retransfer the pool at about 150MB/s which is probably quicker or as fast as rebuilding a RAID array that also lost a drive.
As for saving space using lesser bitrate. Why not? Bitrate isn't everything. I used to think it was until I did real world comparisons. Consider x264 vs x265. These days, video can be drastically
improved with the bitrate cut in half which in turn reduces the file size dramatically as well. It's called Ai enhancing (I suggest RIFE algorithm). Add some 60fps instead of 23.976 to enhance motion better (knowing full well 23.976 wasn't bad) and viola... you have just saved yourself storage space while increasing video quality better than the original studio processed disc. Did I mention you can also add Dolby Vision with further processing using DaVinci although personally this doesn't interest me.
Forget all the white paper science, the measuring meters, corporate greed propaganda, the mob mentality, etc. Just use your own eyes. Pixel peep if you desire. A really quick test - pause a frame on any popular mainstream retail disc. SDR, HDR, older title, newer title, it doesn't matter. Compare the same frame to an Ai enhanced frame. Yep, all the noise and any type of unwanted grain and artifacting is... GONE. And 60Hz instead of 23... more frames per second - more information - fluid unmatched motion provided your display is up to par and many are. I think Ai used for wholesome purposes is incredible.
Here's a comparison of 2160p UHD ATMOS RIP's from the same source. A 1:1 from the disc iso and the Ai enhanced mkv. Notice 44GB at 109 Mb/s vs 34.6GB at 40.6 Mb/s.
Code:
General
Complete name : M:\BDMV\STREAM\00003.m2ts
CompleteName_Last : M:\BDMV\STREAM\00091.m2ts
Format : BDAV
Format/Info : Blu-ray Video
File size : 44.0 GiB
Overall bit rate mode : Variable
Maximum Overall bit rate : 109 Mb/s
Frame rate : 23.976 FPS
Video
Menu ID : 1 (0x1)
Format : HEVC
Format/Info : High Efficiency Video Coding
Format profile : Main 10@L5.1@High
HDR format : SMPTE ST 2086, HDR10 compatible
Codec ID : 36
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0 (Type 2)
Bit depth : 10 bits
Writing library : ATEME Titan File 3.8.3 (4.8.3.0)
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Matrix coefficients : BT.2020 non-constant
Mastering display color primaries : Display P3
Mastering display luminance : min: 0.0050 cd/m2, max: 1000 cd/m2
Audio #1
Menu ID : 1 (0x1)
Format : MLP FBA AC-3 16-ch
Format/Info : Meridian Lossless Packing FBA with 16-channel presentation
Commercial name : Dolby TrueHD with Dolby Atmos
Muxing mode : Stream extension
Codec ID : 131
Bit rate mode : Variable
Bit rate : 640 kb/s
Maximum bit rate : 9 858 kb/s
Channel(s) : 8 channels
Channel layout : L R C LFE Ls Rs Lb Rb
Sampling rate : 48.0 kHz
Frame rate : 31.250 FPS (1536 SPF)
Compression mode : Lossless
Delay relative to video : -1 ms
Service kind : Complete Main
Number of dynamic objects : 13
Bed channel count : 1 channel
Bed channel configuration : LFE
Code:
General
Unique ID :
Complete name :
Format : Matroska
Format version : Version 4
File size : 34.6 GiB
Duration : 2 h 2 min
Overall bit rate : 40.6 Mb/s
Frame rate : 59.940 FPS
Movie name :
Encoded date : 2024-07-04 07:08:36 UTC
Writing application : mkvmerge v85.0 ('Shame For You') 64-bit
Writing library : libebml v1.4.5 + libmatroska v1.7.1 / Lavf61.3.103
VIDEOAI : Enhanced using amq-13
Video
Format : HEVC
Format profile : Main 10@L5.1@Main
HDR format : Dolby Vision, Version 1.0, Profile 8.1, dvhe.08.08, BL+RPU, no metadata compression, HDR10 compatible / SMPTE ST 2086, Version HDR10, HDR10 compatible / SMPTE ST 2094 App 4, Version HDR10+ Profile A, HDR10+ Profile A compatible
Codec ID : V_MPEGH/ISO/HEVC
Bit rate : 25.5 Mb/s
Height : 1 600 pixels
Display aspect ratio : 2.40:1
Frame rate mode : Constant
Frame rate : 59.940 (60000/1001) FPS
Original frame rate : 59.524 FPS
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.069
Stream size : 21.7 GiB (63%)
Default : Yes
Forced : No
Mastering display luminance : min: 0.0001 cd/m2, max: 1000 cd/m2
Maximum Content Light Level : 1030
Maximum Frame-Average Light Level : 146
Audio #1
ID in the original source medium : 4352 (0x1100)
Format : MLP FBA 16-ch
Codec ID : A_TRUEHD
Bit rate : 5 713 kb/s
Frame rate : 1 200.000 FPS (40 SPF)
Bit depth : 24 bits
Stream size : 4.87 GiB (14%)
Title : TrueHD 7.1 Atmos
Language : English
Default : Yes
Forced : No
Original source medium : Blu-ray
