  • Everything You Wanted to Know About HDMI Cables. Ep. 7 of the AVSForum Podcast is now live. Click here for details.
madVR Player Support Thread
34 reading
1.3M views 11K replies 648 participants last post by  biglen
#1 · (Edited by Moderator)
This thread is dedicated to listing the media players and media front-ends compatible with the madshi Video Renderer (madVR).
How to Get Help Here at AVS Forum
What is madVR?
website: madVR is a high-quality DirectShow video renderer. Designed as a no-compromise approach, madVR tries to achieve the best possible video playback quality.
Download Link & Official Support Forum
What can madVR do?
madVR Features:
  • High-quality chroma upscaling and image scaling (Lanczos, Jinc, super-xbr, Reconstruction, NGU, etc.);
  • High bit-depth processing (32-bits per component) to reduce color errors and color banding;
  • Error diffusion dithering to bit depths of 10-bits or less;
  • High-quality HDR tone mapping and HDR10 passthrough;
  • Post-process image sharpening, debanding, deringing, deblocking and denoising;
  • 3D LUT gamut & transfer function correction for display calibration;
  • MPEG4-MVC 3D support;
  • Smooth motion playback without 3:2 pulldown judder, even at 60Hz;
  • Forced film mode turns 60i movies into perfect 24p;
  • Very reliable playback using automatic fullscreen exclusive mode;
  • Bypasses graphics card's video algorithms;
  • All work is done via GPU shaders;
  • No shortcuts — highest quality has priority over anything else.
Note: This software is currently under development and the list of available features can change regularly as it heads towards a distant v1.0 release.
What Platforms does madVR Support?
As DirectShow software, madVR is compatible with Windows operating systems (Windows XP and newer).
  • Requires a GPU with full D3D9 / PS3.0 hardware support.
Desktop Media Players with madVR Support:
Integrated Media Players & Front-Ends with madVR Support:
Calibration Products Supporting madVR 3D LUT Creation:
madVR Set up Guides/How-to Resources:
System Tweaks Needed:
These are some additional tweaks you may need on your system to solve various driver problems etc:
To fix a stutter about 30 seconds after starting any video on recent nvidia drivers, you can add this registry key:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\Dwm
add a new DWORD called "OverlayTestMode" and set the value to 5.
To fix general stutter in madVR that is not related to dropping frames, try some of these settings:
  • set video card to "maximum performance" in nvidia control panel
  • In madVR settings under render, windowed mode pick "present several frames in advance" and set the number of frames to 1.
  • If using exclusive mode, do the same under render, exclusive mode.
If you have any other links, please share!
#2 ·
HCFR doesn't support 3DLUT creation. It's for manual calibration but one can use it to measure and verify a 3DLUT created by ArgyllCMS + dispcalGUI. Also ArgyllCMS is with a lower case l not an upper case I. ;)
#3 · (Edited)
I am confused by the title of Argy11CMS. Is it two ones "11," two L's "ll," or two I's "II?"
#8 ·
With the recent addition of 3D, JRiver with built in Madvr is my paradise.
My Htpc does everything I was hoping including using a 3DLUT file to tune my projector picture to perfection.
Previously I had a chromebox with openelec/Kodi. But no 3D, no 3DLUT and it choked on my VC1 titles also.
What container are you using for those 3D files? Is it playing Frame Packed, SBS or T&B 3D? Thanks.
#9 ·
Apparently Madvr only supports the direct rips that MakeMKV makes. Which is frame packed 3D. This is good for me because SBS or T&B would result in lower quality.
This 3D support is very recent also... but It totally works awesome for me. I was using Stereoscopic Player before but MadVR does better with it.
#10 ·
I'm reading things here but am not currently using KODI nor a member of that forum so I'm hoping for a little bit of assistance over here on AVS.
Where to get LAV 0.68.0? I only see 0.67.0 on GitHub.
Also, I'm running 64bit MPC-HC which has LAV 0.64.0 built in and I notice that my version of the 32bit MPC-HC has LAV 0.65.0 built in.
I'm running MPC-HC 1.7.10 for both AFAIK.
Thanks..
#11 ·
Thanks..
#12 ·
Thanks..
I think Warner/Onkyoman made a typo in the Kodi thread. We're currently at 0.67.0-76 (http://files.1f0.de/lavf/nightly/). Sounds like you're not running the latest MPC-HC version either. You can find those here: https://nightly.mpc-hc.org/. The nightly releases have been a little slow lately, but they always include the latest available nightly of LAV at the time. Even with an older version of MPC-HC you can still manually update the LAV Filters, though.
#13 ·
Thank you!
I can put in the current LAV as an external filter in MPC-HC. Do you know what version of LAV is in nightly MPC-HC?
#14 ·
Thank you!
Not off the top of my head, but once you install the latest MPC-HC, just go to "About" in the menu, and it will tell you the version. You don't even have to setup LAV as external filters. You can just drag and drop the necessary files from the LAV install folder to the MPC-HC install folder.
#15 ·
Easy as that.. basically just overwrite the built in LAV with the nightly. I'll give it a go! Thanks!
#16 ·
Yes, but I know you're trying to get everything going for 3D, so you also need to download the extra 3D stuff for LAV. Make sure you check that extra box in the installer. I can only assume that you can just copy the extra files to the MPC-HC filters folder as well, but I have no experience with those. Give it a shot and report back.
#17 ·
Is this in MPC-HC x64 or x86?
BTW, I guess I need to read that thread a little more to see what "extra" things to which you refer..
#18 ·
The nightly folder has both x86 and x64, so make sure you get the right one, or both. I usually get the zipped ones, not the executables, but it doesn't make a difference. Since madshi and nev implemented 3D playback, LAV now has an extra option to install the necessary files for that. By default, that is unchecked.
#20 ·
That's MPC-HC 7.10.101 which has 0.67.0.70 LAV included. Is 0.67.0.76 necessary for 3D playback?
