In the final planing stages for my construction and have come to a question on the best placement of the front speakers.
The room will be about 13' wide and the screen will be about 100"-105" wide. The primary seating will place your head about 12'-13' away. I plan to use an acoustically transparent screen so center placement is not an issue.
The question is to the placement of the front L/R. if I place them behind the screen the separation angle as it relates to the seating position will be somewhat narrow, even if I place them toward the outer edges (even worse for the 2nd row).
If I move them outside the screen I can come much closer to an optimum separation angle. But... In a 13' wide room that places them right next to the side walls.
So, with this room strictly for movies-no music (except for the music in movies), wich situation would be worse for the movie experience? The narrow angle or the problems associated by placing speakers too near the side wall? Could the negative affects of placement near the side walls be mitigated by some room treatment?
When I first envisioned this I liked the idea of all the fronts behind the screen, but am afraid I will have to move the L/R out to get some separation. Otherwise I fear it will sound like one speaker back there.
Looking forward to your input.
