Marantz Unveils AV20 and AMP20 with Dirac ART Set for a Future Firmware Update
5 reading
14K views 60 replies 32 participants last post by  dunnersfella
#1 ·
Marantz has introduced two new additions to its reference home theater lineup: the AV 20 AV Preamplifier and AMP 20 Power Amplifier. Both models follow the company’s recent AV 10 and AMP 10 and are designed to give home theater users additional configuration options at the top end of Marantz’s lineup.
The AV20 and AMP20 are developed and assembled at the Shirakawa Audio Works facility in Japan. Marantz notes that both products are designed to function either together or alongside other models in the lineup. The AV20 and AMP20 feature the iconic porthole display and an industrial design which includes multi-layer chassis construction with heavy copper use. On the AV20, a fold-down front panel hides less-frequently used controls for a cleaner appearance. Both products are equipped with fascia plates with adjustable side illumination.
The AV20 relies on Analog Devices SHARC dual-core DSP and 32-bit two-channel DACs, with dedicated jitter reduction. This provides the power needed to process everything from high-resolution stereo to today’s most immersive formats, including Dolby Atmos, IMAX Enhanced, DTS:X Pro, and AURO-3D.
For calibration and room correction, the AV20 comes with Audyssey MultEQ XT32. A microphone is included for automatic calibration of speaker sizes, distances, and level. That’s not all though. There’s also support for optional Dirac Live Room Correction and Dirac Live Bass Control which gives users the ability to calibrate up to four independent subwoofers. Later this year, Marantz plans to add support for Dirac Live Active Room Treatment (ART) through a firmware update, which will be available as a separate purchase.
Each of the AV20’s seven HDMI inputs can pass through up to 8K/60Hz or 4K/120Hz video. The new high-res user interface makes setup and customizations more straightforward. Both RCA and XLR outputs are available and up to 13.4 channel system configurations can be used. There’s also multiple analog and digital inputs. Streaming and multi-room audio are integrated through the HEOS platform. The AV20 is also compatible with Roon, Spotify Connect, TIDAL Connect, Qobuz Connect, AirPlay 2, and Bluetooth.
The AMP20 is a 12-channel power amplifier rated at 200 watts per channel into 8 ohms (1kHz, 0.05 percent THD, two channels driven). It can also be reconfigured in bridged mode to power up to six channels at 400 watts each, or bi-amp up to six speakers. Marantz notes that the AMP20 can be combined with the AV20 or other Marantz components, including CINEMA 30 and AV10. If a system requires more than 12 channels, users can opt for the 16-channel AMP10 instead.
Both the AV20 and AMP20 will be available starting today at $6,000 each and can be purchased through Marantz.com and selected retailers.
Key Features
Marantz AV20 AV Preamplifier
MSRP: $6,000 (USD) | €5,500 | £4,750
Marantz AMP20 12-channel Power Amplifier
  • SHARC dual-core DSP with 32-bit two-channel DACs
  • Iconic Marantz porthole display with modern, high-definition on-screen display
  • 8K support for all 7 HDMI inputs, plus 3 HDMI outputs
  • Compatibility with Dolby Atmos, IMAX Enhanced, DTS:X Pro, and AURO 3D
  • Audyssey MultEQ XT32 advanced room optimization included
  • Dirac Live calibration, Bass Control, and Active Room Treatment available as paid upgrades
  • Built-in HEOS for multi-room streaming, plus Spotify Connect, TIDAL Connect, Qobuz Connect, Roon Ready, AirPlay 2, Bluetooth, and more
  • 12 x 200W Power Amplifier, with bi-amping and 400W BTL mode
