Plasma TV with s-video input?
1 reading
10K views 32 replies 18 participants last post by  Servicetech571
#1 ·
Do you know of any current (as of Sept 2011) plasma TVs that have s-video inputs?
I am unable to find any websites that offer a way to search by inputs.
I'd like something in the 46-51 inch range if possible.
720p is fine, it doesn't have to be 1080.
As an absolute last resort, I could buy one of those S-Video to HDMI converter boxes for about $80 off of Amazon, but I'd rather not have to.
#2 ·
Why would you want to do this??
S-Video is the next to worst video interface (after composite) and is limited to 480i (will not pass an HD image)!!!
#3 ·
Because it is the best quality output of a number of devices and is substantially better than composite which is typically the alternative.
If you buy an S-video to HDMI converter make sure it isn't one that forces upscaling.
And please don't get a 768p plasma. They're such a step down from 1080p for so little price advantage.
#4 ·
Correct. I have several older game consoles that can only do S-video (or composite), as well as a heavily modified Series 1 TiVo with a lifetime subscription that I'm not quite ready to give up yet.
If you can't tell, I'm being forced, kicking and screaming, into the HD future and I'm not entirely happy about it. Having an s-video port allows me to keep one foot in the past, at least for the time being.
#5 ·
LG, Panasonic, and Samsung are the three current manufacturers of plasma tvs. I'm pretty sure that LG and Panasonic no longer have S-Video inputs on their consumer sets. Not certain about Samsung.
I would normally suggest an AV receiver with video conversion but even the flagship models of (Marantz, Denon, Onkyo) no longer have S-Video inputs. Perhaps you can find a model from a few years ago on Craigslist that will internally convert S-Video to Component (or HDMI).
Aside from that, the only real option for Plasma + S-Video is to get a Panasonic Pro monitor with an S-Video input card. $$$$.
#11 ·
This was my thought, as well. I would imagine there are plenty of people upgrading their HDMI receivers to ones that can handle 3D, so they should be offloading them.
For instance, my 3-year old Denon AVR-1909 has plenty of S-Video and composite inputs and will upconvert all inputs to HDMI, but it won't handle 3D over HDMI. Something along these lines would be an excellent way to convert composite/S-video sources to HDMI.
#12 ·
EXCELLENT! Thank you. I never even considered an AV receiver. I have ZERO interest in 3D, so that looks like good option. Denon AVR-1909 can be found used on Ebay for $250. I'll have to look around and see what the top-rated AV receivers were 3 years ago.
Do you have any idea how much lag is introduced by the upconversion in the receiver?
#13 ·
I see people saying this, but I don't currently have any HD content. I don't own any of the HD capable game systems, I really don't have any interest in paying $150+ a month for digital cable, and I'm definitely not going to re-purchase my movie collection in Blu-Ray format. So I'm not sure it's worth spending $200+ extra for the 1080p at this time.
Is there something I'm overlooking?
#14 ·
Yes you are overlooking the fact that OTA signals are capable of 1080i and your regular dvds can be scaled to hd. Also that you can in the future purchase blu rays and be in this century (pardon the harsh language).
Also the huge fact that you will get better overall picture quality with a less reflective panel, deeper blacks, and better contrast.
#15 ·
Are you currently using a CRT display? If so, the transition to a fixed pixel display for SD material will be a real disappointment.
#16 ·
krick, I'm in the same boat as you with the need for s-video. I play a lot of old gaming systems that dramatically improve video quality with the use of s-video over composite. It is disappointing manufacturers can not include this input anymore (as well as analog stereo out). Like others have already mentioned, look for a receiver than can decode the signal, or pick up a s-video-to-component converter. Both options are pricey, but that's about all you can do nowadays
#18 ·
Probably the two most popular AVRs in 2008 were the Yamaha RX-V663 and the Onkyo TX-SR606. Here are some links to the owners threads, along with the thread for the Denon 1909:
http://www.avsforum.com/avs-vb/showthread.php?t=995796
http://www.avsforum.com/avs-vb/showthread.php?t=1026622
http://www.avsforum.com/avs-vb/showthread.php?t=1050097
The Denon was pricier, but considered a step up. The Yamaha I believe only had 2 HDMI inputs, while the Onkyo had 4 (if memory serves; I researched them both back when I ended up getting the Denon). The Onkyo did seem to have more problems, but was a lot of bang for the buck. I'm not sure how many S-Video/composite inputs they had, but it should be easy enough to figure out.
I never noticed any lag, but I didn't do any serious gaming through them (just a little Wii). I doubt it would be noticeable.
#19 ·
There is no point in doing "upconversion" outside of your display. You display will be optimized to converting to its own native resolution.
#20 ·
Presumably you are watching DVDs and broadcast TV.
Both of these are severely limited by the use of S-video. You will get much, much, much better visuals using component or HDMI from DVDs and broadcast TV.
If you are actually watching VHS, then you're better off finding an old CRT than using a plasma
#22 ·
For those of you who simply want to talk the OP out of this, please read the whole thread first. Here's his statement of why he wants this:
He's not just watching TV or an old DVD player, he has several specific devices he still wants to use and the best they have to offer is S-Video. I don't understand the need to make fun of him or tell him it's a bad idea. The results won't be that great, but could still be usable. And if it doesn't work that well, he can then move on to more up-to-date sources for his brand new HD plasma.
#23 ·
The AVR will have to convert from analog to digital at a minimum. Whether the AVR upscales better than the TV would be a coin toss. Either way, I doubt there's noticeable latency.
#24 ·
The catch is:
If he buys a "720p" TV, I would bet you dollars to donuts that it ISN'T 720p !! It will be 1024x768 or 1366x768 - neither of which is 720p ! 720p is 1280x720.
So ... if you use an external conversion device (ie. AVR) that offers conversion to 720p, the TV will still have to convert from 720p to its own peculiar bastard resolution.
It's bad enough to have to convert resolutions the first time. It is IMPOSSIBLE to convert resolution without creating distortion and artifacts. You should NEVER do it twice !!
#25 ·
I was looking to replace my G9 Kuro with a bigger plasma. I use two S-VHS vcr's to time shift cable thru the wall. I don't think any of thse new displays have S-video or RCA in's. My Pioneer Elite SC35 AVR has none.
