  • Manufacturing, Myths, and Misfires with HDMI Cables. Episode 9 of the AVSForum Podcast is now live! Click here for details.
Time for a front stage upgrade.
3.4K views 15 replies 10 participants last post by  craig john
#1 ·
I'm still running polk monitor 60s , and a cs2 center I've had for probably about 10+ years. Just looking to see what I can get for a good upgrade for around $1000. They still sound ok, but looking to get a nicer , fuller, crisper setup. So basically move up a few steps.
Currently have a pb1000 for the sub and some bookshelves for the rear ( only 5.1 for now )
Av is an onkyo 686
Was looking at the svs prime towers and center, which would be over budget by about $400.
I'm all ears, and like I said , just looking for a better overall speaker set, that I can actually notice ..
3097898
3097899
#2 ·
When it comes to the front 3 , I'll basically find the best center channel I can get , then pair that with the matching towers.. I don't know if it's the look, or reviews , but these have caught my eye for a while
3097900
#8 ·
If you like Polk products, this is the only decent center speaker they make:
If your usage is mainly TV/movies you can easily keep your Monitor 60s and just go with that 706C if you want something with a pretty cabinet that actually sounds good.
If VISUAL uniformity is important, $1K would buy you a pair of Emotiva T0 with C2+ center for $800, or T1+ with C2+ for $1100.
Unfortunately, you missed the last great Infinity Reference sale...you could have gotten a pair of towers and a great center speaker for just $500 all in.
If you can live with bookshelves on stands, I'd get 3 x Chane A2.4 for around $900 shipped.
#3 ·
I went from a similar Polk set up to a set from Elac, specifically the Uni-Fi 1.0 5 series towers and center. It was a noticeable difference for me and the overall soundstage and clarity improvements were definitely worth the cost. For $1000 you are right on the cost for a front stage of their Debut 2.0 series. They do run deals quite often so you might be able to get it a bit cheaper or even get their Uni-Fi line for your price. I also sold my polks to offset some of the cost.
Other great option -
Emotiva - probably the best performing center channel option in your range. If movie watching is primary goal this is a big advantage as mentioned in the prior comment that centers drive the results for home theater.
#4 ·
Thanks for the reply.. I'll just have a 5.1 , possibly 7.1 setup for now..
I'm in the middle of remodeling the basement and the home theater room is also kind of a rec room.. so 7.1 would be nice, otherwise I'll just take my current 5.1 , get a new LCR, and call it a day..
Primarily 50% movie / 50% music gaming
#5 ·
If you're looking for a front wall (LCR) upgrade for $1000 ... Emotiva C1+ ($299) and T1+ ($699) (or for ~$1100 total get the C2+).
I'm only 60 days into my HT refresh I did with all Emotiva speakers and the center channel dialogue is amazing (and the LR bring out details I've never heard before) ... my previous CC was a Polk LSIM704.
  • Like
Reactions: cocrh
#6 ·
I had the S35 and it we decent, but it did not have much depth. I think you pay a premium because there are not a lot of centers that are so short. People give it good reviews because it is ok and the best option for WAF. I did not think it was worth the money, if I had not had space constraints I would have bought something else.
#7 ·
The Emotivas above, or the Infinity Reference speakers when on sale.
Crutchfield had the Klipsch RP-280F and RP-450C speakers on sale for $399 each.
  • Like
Reactions: LanceUppercut420
#10 ·
Thanks guys. The monitor 60s are still fine. I don't listen to much 2.1 anyways. So the idea of spending a bit more for a good center channel is a good suggestion.. everyone always talks about matching your LCR, that I didn't even think about keeping the LR for light duty
#11 ·
The only way to truly "match" your front 3 is to use an IDENTICAL speaker for the center---for example, a 3rd Monitor 60. The idea that a horizontal center speaker from the same brand, which often has different sized woofers and crossover points, can in any way "match" the "timbre" of the L/R speakers is a steaming load of HS.
However, whether this mythical "timbre match" even matters in real life HT usage, is also debatable.
#12 ·
To see how multiple people are finding out FOR THEMSELVES just how silly the whole "timbre matching" hoopla is, start with post #19 of this thread:
There are many more threads like that:
Hsu HC-1 with NHT SuperOnes
Infinity RC263 used with JBL 590s
Infinity RC263 with Emotiva T1, vs C2
Emotiva C2 with Klipsch RP-600M, JBL Studio 530, etc.
Klipsch RC-62ii with JBL 590:
Klipsch RP-450C with JBL 590
Emotiva C2 with Revel F35, and with JBL 530:
Polk 706C with Legacy Signature II:
SVS Ultra center with Polk LSi-9
Emotiva C2 with Mission 770
Emotiva C2 with JBL Studio 590
and
KEF Q650 with Polk RTiA3
Emotiva C1+ with Wharfedale Diamond 225
Paradigm center with B&W in-wall speakers
Hecor Aurora with Revel F208
HTD Level 3 with Def Tech BP30
Monoprice 365C with PSB Stratus:
Chane 752 with JBL Studio 590:
Canton Chrono 505 with Polk LSiM-703:
Emotiva C2+ with Klipsch RP-600M:
#13 · (Edited)
I'm still running polk monitor 60s , and a cs2 center I've had for probably about 10+ years. Just looking to see what I can get for a good upgrade for around $1000. They still sound ok, but looking to get a nicer , fuller, crisper setup. So basically move up a few steps....
...I'm all ears, and like I said , just looking for a better overall speaker set, that I can actually notice ..
I've said this on several other threads, but after years of moving between consumer hi-fi speakers - I've gone with active speakers - and will NEVER go back!
Why?
The sound quality is simply in another league. They have specially matched amps, built in for each driver (so bi- or tri-amped), with active crossovers and DSP - and are designed for accuracy for professional sound mixers.
(They're also much better value for money, all told.)
Some excellent examples that have larger drivers and front bass-ports include:
  • Presonus Eris E7 or E8 XT
  • Kali IN-8
  • Fluid Audio FX8 or FX80
  • Focal Alpha
  • KRK Rokit G4 - 7 or 8
  • KRK Rokit G4 - 10-3
  • Tannoy Gold 8
  • Presonus Sceptre S8
With any of these, most people would actually get away without a subwoofer, but for best results, this one is amazing bang for buck:
  • Presonus Temblor T10
You would need a receiver with pre-outs, btw.
#14 ·
Why?
Some excellent examples include:
  • KRK 10-3 G4
  • Kali IN-8
  • Tannoy Gold 8
prob better then low end gear .
Some people love horns , some like professional speakers. Monitors can be excellent yes , cheapest amp with pre outs is $1400 or more.
No type of speakers are superior all opinions .... been debated 111100x over
Wish I knew they worked with receivers... lost a cheap pair I could’ve had .
I’m sure studio monitors are good but might just be better in your opinion. They do not hit as high spl as hifi or pro gear , maybe it’s due to them sounding accurate for music recordings . For movie dynamics I wouldn’t expect them to stand a chance vs larger speakers .
Plus op wouldn’t be able to buy a a matching center or anything close .
Some studio monitors are over 3k, there not that different from hifi speakers just for a built in amp.
  • Like
