2,761 - 2,780 of 17,007 Posts
okay,You can display the stimulus pattern in question, 70% window, use free measurement to observe the measured xyY value while changing your gamma setting for 70% in the TV/projector, and align the measured Y to the target gamma Y as shown in the measurement table.
I'm pretty new to HCFR, but this still seems like a bug to me.
I ran saturation measurements and they seem to be plotted correctly on the CIE diagram, but when I click on a specific value in the measures tab the target is showing a huge value for deltax or deltay (in the yellow popup, and also in the location of the arrow). 0% and 100% saturations might be correct, but there's something wrong for 25%, 50% and 75%.
Here's the CIE diagram, with the 75% red point highlighted:
Now, for the same 75% red point, look at the target in the next image and it shows delta x: 78.9% (which is surely much too large):
I also attached the complete .chc file (zipped).
NaturalECOMemory1.zip 4k .zip file
Thanks. Is there any reason why the target couldn't be made to work in other cases? Or maybe I'm missing the whole point of it. Other than being confused by the target, the software has been very easy to use and does everything I need.
One more thing. I have an i1Display Pro, and notice there is only one generic .ccss file for projectors. Can I assume that's going to be accurate enough for any LCD projector? (I'm using it with an Epson 5030). I have no way to make my own correction matrix, so I'm hoping that's the case. Being new to this, it's a little unsatisfying to realize that you have no simple way of knowing how accurate your meter is.
Originally Posted by kriktsemaj99  /t/1393853/fork-of-hcfr-started-whats-needed/2760#post_24005774
As it stands now the target indicator is auto-selecting the current primary/secondary color that you are calibrating (with constant measuring). I.e just start measuring constantly and select the color pattern that you want to calibrate - zapp the target indicator switches to the corresponding color. Very neat and makes it easy to switch between colors when calibrating CMS. Just change pattern andf the target indicator follows.
It does this by looking at the primary/secondary color that is neareast to your mesurement by dE comparison. That is why it can not work for saturation sweeps as the dE is too close to separate the different targets.
As neat as this is I have proposed a change to the current scheme that the target should be possible to focus on a specific target column by clicking on it. Mostly for grayscale settings so that the corresponding target column gets updated with "live" data and not just the indicator on the left. That should save us a few full grayscale sweeps to get graphs updated when we calibrate I think. For color the current scheme works pretty well although better consistency between grayscale and CMS calibration procedures would be nicer and less confusing for users.
As for the target indicator showing false deltax when selecting a saturation sweep target column, I too would consider it a bug. It would be better IMHO if the target indicator was disabled altogether when an data column that it does not support is selected.
As always, it is up to the coders in the project to prioritize what is important and what is not. The work done so far is great, and I can surely live with these little quirks. A good way to deal with them though is to document in the wiki. I might be able to help out there if needed.
Yes, the lamp type of all the common LCD projectors is pretty much the same, meaning the spectral output matches closely. The ccss correction works in conjunction with the firmware in your D3 meter and reads it's specific filter coefficients and thereby calculates a correction matrix. It is not as ultra-accurate as having a reference spectro and create your own correction matrix, but the difference is very minor. A number of posts earlier have dealt with this and the dE between spectro and ccss+D3 is mostly insignificant.
That said, I also would like to have a spectro just to get that last accuray. It is just to darn expensive though...
The improvements to HCFR since I first found it in March are amazing. Hats off to the developers, I can't believe this software is free.
Discussion starter · #2,768 ·
Originally Posted by 10k  /t/1393853/fork-of-hcfr-started-whats-needed/2760#post_24007276
I have a small update available to version 3.1.0.4
Changelog
I've added a "white reference weighting" option to the dE formulas. When either "Gray world" or "Dark" is selected, all the dE calculations are scaled using a white reference of 15% or 5% relative luminance respectively. This is somewhat similar to what the relative Y switch does for gray scale. The dE value with these weightings give you an idea of what the actual color error would be if your vision was adapted to those luminance levels. 15% is a good estimate of what your typical adaptation level will be during a majority of video content viewed in a dim environment.
Originally Posted by Andrei_VVB  /t/1393853/fork-of-hcfr-started-whats-needed/2760#post_24009585
Larry I've changed my st60 with vt60. I want to ask you what were the patterns that gave the best results in your calibration ? Also, do you have a slightly pink tint in the centre of the screen? Both st60 and vt60 were the same. Thank you!
Andrei,
I now have two VT60 units -- the 65 inch in the living room and a relatively new 60 inch in the bedroom. Both seem to look best when calibrated using the 6.5% normal windows from Ryan Masciola's disk.
WRT the screen uniformity: My 65 inch has a very slight pinkish area along the bottom 3 to 5 inches of the screen when a full screen gray pattern is displayed but this is not noticeable under normal viewing. The 60 inch has near perfect uniformity.
Larry
Zoyd,
I get really confused with dE values for primaries and secondaries and with dE values for saturation sweeps:
First I measure gray scale.
Then I press "Measure primary colors".
I can view dE values by selecting "Primaries and Secondaries" in "Measures" tab.
Red dE = 1.6 in this case.
Then I press "Measure red saturation scale"
I can view dE values by selecting "Red saturation scale" in "Measures" tab.
Shouldn't 100% red saturation dE value be IDENTICAL to the red color dE value under "Primaries and Secondaries"???
Because it often isn't! I understand that each measure may produce slightly different results because of margin of error from my colorimeter, but sometimes that number is just way off! Have I falsely assumed that measuring colorspace is the same thing as measuring 100% saturation for each color?
BTW, the CIE diagram only shows the XY value for targets, but it does not show the luminance. So, technically, moving closer to target could actually increase dE value if moving closer to target has an effect on luminance, right? That is the case with me... I can improve my XY coordinates greatly, but it will result in a higher dE value.
EDIT: OK, even when I reduce my contrast drastically to greatly improve my overall RGB and grayscale luminance my dE value is higher when the red dot for 75% saturation is in the dead center than if I were to decrease saturation so that that the red dot is further away from the target.
To closer to target = higher dE value. Are those targets exactly where they should be?
Discussion starter · #2,777 ·
Originally Posted by MonarchX  /t/1393853/fork-of-hcfr-started-whats-needed/2760#post_24017996
yes, all targets are calculated correctly. Note that any target with less than 100% saturation depends on gamma so be sure that if you have the gamma reference set to "use measured" that you have run a proper grayscale and that if you don't have this box checked that the value in the reference box correctly reflects your actual average gamma. Often times minimum dE will not occur when x,y is exactly aligned with the target depending on delta luminance. If luminance is high, a slight desaturation can offset that and result in a lower dE, it'a all about trade-offs (unless you have a 3dLUT
Originally Posted by zoyd  /t/1393853/fork-of-hcfr-started-whats-needed/2760#post_24018566
yes, all targets are calculated correctly. Note that any target with less than 100% saturation depends on gamma so be sure that if you have the gamma reference set to "use measured" that you have run a proper grayscale and that if you don't have this box checked that the value in the reference box correctly reflects your actual average gamma. Often times minimum dE will not occur when x,y is exactly aligned with the target depending on delta luminance. If luminance is high, a sleight desaturation can offset that and result in a lower dE, it'a all about trade-offs (unless you have a 3dLUT
Hmmm... Well, I lowered my contrast to a point where gray scale & RGB luminance all line up almost perfectly. Then I ran a gray scale measure, which produced a near-flat 2.2 gamma. However, once again, moving red saturation closer to target increased dE...
There is really no way to control specific color luminance other than adjusting contrast and brightness to get gray scale AND RGB luminance aligned, right?
How can you adjust CMY luminance then?
I often see calibration reports include luminance information by showing a specific color luminance and gray scale luminance for that color. They should be the same. In my case, that almost never happens.
