Building a theater under my covered porch. I'm working with Nyal on acoustics and I'm trying to understand how the ceiling construction would actually work.
Nyal is recommending ICC clips, 5 ½" spray foam, 5 ½" batt insulation.
My ceiling will be all slab no floor joists etc.
So... would the entire ceiling get sprayed and then I would need a hold drill bit to cut away the spray foam and attach the ICC clips? There's moving parts so there's no way I would mount the clips before the spray.
Thoughts? Suggestions? What did you do?
Thanks for taking the time.
